Savin 9935 DPE / Aficio 350E Banding marks on copies
  • Buddy
    • Aug 2009
    • 285
    Yes, I know it's an old but machine, but I got a chargeable call from a new customer. I have attached a sample. I'm thinking charge roller? Not really sure. (Obviously, or I wouldn't be posting here now would I? ) Suggestions? THANKS
  • ccchuah
    • Mar 2009
    • 157
    Re: Savin 9935 DPE / Aficio 350E Banding marks on copies
    The two pieces of metal spring which supply the bias is not in contact with the charger roller
    • TonerMunkeh
      Professional Moron
      • 3865
      Either that or the drum is completely shot. I'd go with a PCU rebuild, including developer, then go from there.
      Hit it.
      • Iowatech
        Not a service manager
        • 3930
        I'd pay attention to the first two replies first. But if time permits, you might want to take the charge roller out and make sure it and it's cleaner are in good shape, and maybe try cleaning the charge roller with water on a cloth and see if that makes any difference. The way the arc of clear print moves up and down through the dark bands on the test print does kind of make it look like a charge roller problem.
        • Jimbo1
          • Mar 2008
          • 845
          Also on those older machines there was an issue with drum grounding through the bearing which is filled with conductive grease. i would probably try and check that and change it if necessary. It can give you that banding too.
          "Some days you get the bear, some days the bear gets you."
          Cdr. William Riker
          • Buddy
            • Aug 2009
            • 285
            Just wanted to follow up, guys. Thanks to your input, I was able to fix the machine. A little embarrassing, but the problem was indeed the charge roller. The issue was they had a small piece of foam stuck to it! Cleaned the charge roller and all are happy. Thanks again!
