Have another Ricoh problem. This 1232C will run perfect black/while copies and perfect one color copies. But when running in full color the first maybe 3 inches looks as if the colors are not mixing correctly. Second part of color copy is fine. Have swapped lasers and replaced the ccd in scanner. Please give me a hand.
Ricoh 1232C
That's it.
If you're feeling brave, you could try pulling off the assembly and cleaning all the bushings and shafts, but it's not 100% successful. Even after all that work, I've still had some that had to be replaced due to just being worn out.the savin2535 is displaying well bet the hiter lamp is not shining and the lamp had been tested o.k.please kindly help.Samir: No, not again. I... why does it say paper jam when there is no paper jam? I swear to God, one of these days, I just kick this piece of shit out the window.
Michael Bolton: You and me both, man. That thing is lucky I'm not armed.Comment
Take off the top cover and check that the cleaning clutch gear is spinning around, if that looks ok, it will be the clutch pack (which also has this cleaning clutch on it)Networking skills are advantageous but use of a 3m vacuum cleaner is essentialComment
