image issue mpc2500
  • daveh12
    • Jul 2012
    • 157
    [Misc] image issue mpc2500
    hi,
    have a mpc2500 that is giving an image problem. printing, scanning to pc, copying through the df all work perfect, black and white and colour. but the problem is when you copy from the glass, there is a blue/grey blackground on a colour copy. any help would be appreciated on this.
  • Zeldaman
    • Mar 2011
    • 946
    Re: image issue mpc2500
    Hi there!
    Clean the complete optical section & do the ACC. This schould solve your problem.
    Greetings...
    • sandmanmac
      • 3983
      Originally posted by daveh12
      hi,
      Sounds like someone has done a full memory clear. (Big no-no).
      The non-default settings from the birth certificate will need to be re-iput in Sp mode. Hopefully its still tucked inside the front cover
      • Elmo
        • Feb 2010
        • 541
        You need to set
        sp 4685-001
        sp 4685-002
        sp 4685-001
        sp 4686-002
        sp 4687-001
        sp 4687-002
        to the factory settings as show on the sheet inside front door
        I Used To Live To Fix Things Now i Fix Things To Live
        • rsyarcia
          Hair Straightener Tech
          • 711
          clean the white plate and make sure that the exposure glass is fitted properly..
          Nobody is perfect..
          • Ricohguy
            • Sep 2012
            • 48
            Oddly enough, I have had this. Go into Copier/Document Server Feature and turn Auto Density on for color copies.
            • Bantams
              • Jun 2012
              • 603
              That dosnt fix the problem it just hides it until someone who knows how to fix it comes along. Oddly enough we had a RICOH engineer called out to fix this issue and he did just what you suggested because there was no Birth Certificate with the machine in the end I Just Re Input the data as described by Elmo that I took from another machine and Fixed it myself.
              • Llama God
                • Mar 2009
                • 1353
                RICOH engineer? I shit'em!
                • Ricohguy
                  • Sep 2012
                  • 48
                  But... why does it matter as long as it works? The machine I did this to is still in the field and it was done 3 years ago.
                  • Elmo
                    • Feb 2010
                    • 541
                    I have had quite a few mpc's do this for some reason the data gets corrupt/reset
                    if you have the birth certificate great easy an quick just to reinstate values
                    if not its a case of play with the values till you get it right
