anyone have sc995 on a 1075?
  • fshead
    • 2366
    got a call this am for a sc995 on a old 1060/1065 copier.
    i know to check hdd,loose conections,memory,and charge corona for arc..
    am i missing anything?
    its a machine wth about 2mil and i am looking to upgrade them in the upcoming months..
  • fbriggs
    • Feb 2011
    • 22
    Re: anyone have sc995 on a 1075?
    I found that updating firmware got rid of this problem.
    • fshead
      • 2366
      thynx
      i think i can find my flashcard but havent done a 1060 firmware in years..........
      are you doing just engine and system?
      thnx
      • fbriggs
        • Feb 2011
        • 22
        Yes, this would normally solve the problem. But, if you can, i would recommend updating all of it.
        • TonerMunkeh
          Professional Moron
          • 3865
          1060 firmware is SD card isn't it?
          Hit it.
          • fbriggs
            • Feb 2011
            • 22
            That is probably the older, larger one, as opposed to the newer, smaller one.
            • fshead
              • 2366
              no the 1060/1075 use the old big 4meg flash cards..
              the mp5500-7500 use the sd cards,
              and the 2051 between the above"i think",cant say for sure uses the 4meg flash card too
              • Imprestik
                • Aug 2012
                • 296
                Anything from the AF1060-75 downwards requires flash card
                Anything from the AF2051/60/75 upwards has SD card
                • fshead
                  • 2366
                  you are right on that,
                  i didnt sell many of the 2051 series,
                  went to the 5500.6500,7500...
                  which i found out used the same pm parts and fuser units..
                  • fshead
                    • 2366
                    well it turns out my 995 code is really a 955 code,after i make a visit..
                    and to make it more fun it has a sc 122 code when scanning or copying from the glass.
                    scan goes forward on all size originals but on the return just a slight jitter n code out..
                    on repower comes home no problem..
                    blew out home sensor and cl rails..
                    thinking the motor,sensor or board...
                    did not see any 955 code come up...
                    • fshead
                      • 2366
                      replaced home scan sensor,still coding out,and then the brd that connects to the scan motor and that took care of the sc 122
