Ricoh 240w wide AC Drive Board? SC548
  • jdzr
    • 125
    #16
    Re: Ricoh 240w wide AC Drive Board? SC548
    I'm not sure if it is the same sensor used in the analog machines but I know in them the sensor will get dirty on the lens and cause this kind of error. If you don't have a new one just clean it with a q-tip & alcohol. Only thing that bothers me is why you do not get an error code message on the control panel display. One more thing, if memory serves me correctly make sure your sensor is positioned in the right direction. I think that is one you can turn wrong.
