Pro906 Black Band
  • techspec
    • Dec 2008
    • 128
    [CQ] Pro906 Black Band
    We have a Pro906 which is giving a black vertical band about an inch thick running from edge to edge.
    Also there can be text in this area which will be perfectly clear and legible.
    This is an intermittent fault which is very intermittent being and random happening 1 in every 5k or 10 in every 3k
    no relevant error codes.
    Any ideas or solutions would be great.
  • teebee1234
    • 1670
    Re: Pro906 Black Band
    If it's running from lead edge to trail edge then maybe the charge wire cleaner is stalling before it reaches the end of its run, this will cause a black line that width by blocking the charge but still allow some amount by (not sure if it would error out, older models didn't). If it's from front to rear then it might be a pit in the drum causing a charge short.
    The fact that it happens between 1-5k seems about the cleaning cycle for the charge wire.
    • techspec
      • Dec 2008
      • 128
      Thanks for your reply teebee.
      Not the charge cleaner as its running in wrond direction.
      The line is horizontal not vertical and doesn't run from lead to trail edge.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • techspec
          • Dec 2008
          • 128
          why thank you Justmanuals!
          im looking for suggestions not spam!
          Ive got the manuals and many more.
          Do you want to buy one? $10.00
          • Iowatech
            Not a service manager
            • 3930
            If you do have the manuals, you probably ought to check them out before you insult somebody who is trying to help you.
            • Imprestik
              • Aug 2012
              • 296
              Check your grounding plates on your transfer unit
              • techspec
                • Dec 2008
                • 128
                Trying to help me by making a quick buck?! What help is that?
                i put the question to the forum as manuals, knowledgebase and Ricoh have no answer.
                • Iowatech
                  • 3930
                  Actually, based on the information you shared, how was he supposed to know you had the manuals? And that being said, why wouldn't he offer you the opportunity to purchase the manuals?
                  Sort of like you, who according to the information that you shared hadn't even bothered to check the condition of the drum blade and the charge grid on your machine, and you were just looking to mooch free information.
                  • Servtech
                    • Apr 2013
                    • 12
                    have you tried the transfer bias rollers?
                    • techspec
                      • Dec 2008
                      • 128
                      How do you know I hadn't checked the drum blade, etc .....
                      I'm no fool! My post may have been short and sweet and forgive me for not listing all things checked and replaced.
                      Mooching free info?? Not my style fellow monkey. Threw out a question to see if anyone else had came across the issue as Ricoh UK and knowledgebase were of little help.
                      • techspec
                        • Dec 2008
                        • 128
                        Thanks for your reply.
                        I've found in the past with the Bellinis and Katanas when you get transfer wear issues the markings you get are scuff like.
                        Defo not that.
                        Laser related by the look of things. Fitted a laser diode and driver pcb so hopefully any feedback we get from site will be good.
                        • techspec
                          • Dec 2008
                          • 128
                          Thanks for reply.
                          Think more laser related issue and if not I'll be looking towards the memory DIMMS on the controller.
