Change display language on MPC305 SPF
  • entranced
    • Mar 2013
    • 12
    Hi.
    Im trying to change the default language to swedish on this brand new machine MPC305. According to the service manual the default languages can be changed with SP mode (SP5-009-002 to 006) in order to display languages other than the defaults.
    Select a language from the SP mode menu. For example, if “Swedish” should be registered as the first
    language, execute SP5-009-002, and select “11” (Swedish).
    But SP5-009-002 to 006 does not exists on this machine (I have tried special SP-mode also). However SP5-009-201 to 204 does exists (add display language) and concists of multiple bit switches (all set to 0 as default).
    I have searched for Language-firmware and Operation Panel-firmware at My-ricoh.com, but found nothing.
    Anyone who know how to change this?
  • rthonpm
    • Aug 2007
    • 2859
    Re: Change display language on MPC305 SPF
    You'll probably need the language firmware for this model to install the Swedish language pack. It's a relatively new machine so it may be on its initial version. Try doing a search for firmware using the build number as a modifier.
    What language(s) are on the machine now?
    • entranced
      • Mar 2013
      • 12
      The default languages on this machine is German, English, Italian, Spanish and French.
      • mikedci
        • Jul 2010
        • 227
        use the wim to set the available languages. Device management > configuration > system. Then at the machine select the language.
        • entranced
          • Mar 2013
          • 12
          Interesting! I'll check that tomorrow. Thanks!
          • entranced
            • Mar 2013
            • 12
            mikedci,
            It worked perfectly. Many thanks!
