C3500 streaks on front edge
  • tinfox
    • 317
    This problem went away and came back on its own.
  • MitchD
    • Oct 2012
    • 164
    Re: C3500 streaks on front edge
    Looks like the charge rollers in all 4 drums need to be cleaned.
    "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
    • tinfox
      • 317
      Okay. That s what I thought. What was strange is that it went away and then returned.
      • cdog530
        • Nov 2009
        • 66
        Remember you can't clean worn out.
        • tinfox
          • 317
          Not true! I bathe daily!
          • Bantams
            • Jun 2012
            • 603
            Looks like you WILL have to replace all the pcus and the DEVs if the problem keeps coming and going.
            • BATA
              • Mar 2012
              • 27
              try to push the scan unit from down to up , if problem in copying mode only
              • mikadonovan
                • May 2008
                • 2931
                It does look like a pcu problem, but since it disappeared and returned you might check out the transfer cleaning unit also.
                NEVER ASSUME ANYTHING
                • tinfox
                  • 317
                  That's what I thought as well so I put in a new cleaning unit and it made zero difference.
                  The customer is okay for now I put all the paper in LT R so the lines don't show up. I ordered 3 pcus
                  • cdog530
                    • Nov 2009
                    • 66
                    Streaks like this from the charge roller can clean themselves up...it is largely dependent on what the customer is running. If they are making lots of high coverage copies the toner disposal system can't keep up and the charge roller ends up getting contaminated. After the high coverage run they may run regular coverage and the toner disposal system catches up and the charge roller eventually cleans off enough to make the lines go away. That is my experience with lines that come and go...and yes like another post said changing the drum and dev unit together is recommended....crashed developer really clogs up the old disposal system.
                    • sandmanmac
                      • 3983
                      The streaks shown are on an internal colour calibration page, so it's NOT only copy problem
                      • mabawser
                        Tech
                        • Sep 2009
                        • 121
                        unless it is a copy of an already printed calibration page!!!!
                        • tinfox
                          • 317
                          Ha! Beat me to it!
                          • cdog530
                            • Nov 2009
                            • 66
                            Is this an original ACC page?! we must get to the bottom of this if so...replace all mirrors in scanner and user a scissor jack to adjust a twisted frame!
                            • tinfox
                              • 317
                              Lol. Yes it was the original ACC.
