We are experiencing this error a week ago and still not solve even we change the Controller board and BICU board. Anybody here can give us support. Thanks.
Another SC 670 for MP C2550
Re: Another SC 670 for MP C2550
The manual refers to the "engine board" for sc670, not controller board or BICU. What the heck is the engine board ? , I can find no reference to "engine board" in the rest of the manual. And certifiedxeroxtech, I was trying very hard to concentrate on your message, slightly distracting strobe flashing on & off in my face from that avatar. Wow !Comment
Paul@justmanuals.comComment
Have you tried replacing or testing NVRAM? or try disconnecting the HDD or test to replace it? or if happen you replaced a BICU you must inlist the serial number of the machine...fix the customer first then fix the machine... its simple and makes life more easy.Comment
The manual refers to the "engine board" for sc670, not controller board or BICU. What the heck is the engine board ? , I can find no reference to "engine board" in the rest of the manual. And certifiedxeroxtech, I was trying very hard to concentrate on your message, slightly distracting strobe flashing on & off in my face from that avatar. Wow !Nobody is perfect..Comment
The manual refers to the "engine board" for sc670, not controller board or BICU. What the heck is the engine board ? , I can find no reference to "engine board" in the rest of the manual. And certifiedxeroxtech, I was trying very hard to concentrate on your message, slightly distracting strobe flashing on & off in my face from that avatar. Wow !"prepare your contingency plan as always"Comment
Hello
Sc670 = controller baord.
had this many times and it worked.... also check the pins inside the Rj45 conector as these sometimes bend and short the board out.
good luck .........Comment
I'll second that, Ive had the controller board cause SC670!Comment
jesus loves you! (everyone else thinks you're an assh*le)
street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trainedComment
Check the communication cabel between the IOB-BCU (poor connection)Comment
Dear All, this case is closed. Power Supply issue."prepare your contingency plan as always"Comment
