Another SC 670 for MP C2550
  • certifiedxeroxtech
    • Nov 2009
    • 27
    We are experiencing this error a week ago and still not solve even we change the Controller board and BICU board. Anybody here can give us support. Thanks.
    "prepare your contingency plan as always"
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Another SC 670 for MP C2550
    make sure that the boards you used to isolate were tested good.
    Nobody is perfect..
    • andy227
      • Jan 2013
      • 219
      The manual refers to the "engine board" for sc670, not controller board or BICU. What the heck is the engine board ? , I can find no reference to "engine board" in the rest of the manual. And certifiedxeroxtech, I was trying very hard to concentrate on your message, slightly distracting strobe flashing on & off in my face from that avatar. Wow !
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • maniello71
          • Apr 2013
          • 7
          • imaginemoko
            unTrusted Tech
            • Jan 2008
            • 289
            Have you tried replacing or testing NVRAM? or try disconnecting the HDD or test to replace it? or if happen you replaced a BICU you must inlist the serial number of the machine...
            fix the customer first then fix the machine... its simple and makes life more easy.
            • rsyarcia
              • 711
              BICU - BASE- ENGINE and IMAGE CONTROL UNIT.
              Nobody is perfect..
              • andy227
                • Jan 2013
                • 219
                rsyarcia, thanks. Was confused by the manual saying just "engine",instead of as normally, "BICU". Not the normal terminology.
                  • Nov 2009
                  • 27
                  andy227 haha! I am freakin' feelin' bad about issues like these. So I decided to put on some heavy thing while working. We currently order NV ram thing as per experience for these models and hopefully we get the results this week. Thanks for the replies. I will post a feedback soon.
                  • spaceman99
                    • Jul 2009
                    • 174
                    Hello
                    Sc670 = controller baord.
                    had this many times and it worked.... also check the pins inside the Rj45 conector as these sometimes bend and short the board out.
                    good luck .........
                    • johnyb
                      • Feb 2011
                      • 167
                      Originally posted by spaceman99
                      Hello
                      good luck .........
                      I'll second that, Ive had the controller board cause SC670!
                      • ptrflrs
                        Glorified Parts Swapper
                        • Dec 2010
                        • 192
                        yup, controller, i think there is a bulletin on this issue
                        jesus loves you! (everyone else thinks you're an assh*le)
                        street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
                        Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
                        • zsoltee0001
                          • Jul 2009
                          • 39
                          I have met a lot of sc 670 error code (other machine) which i coluld solved.
                          Check the communication cabel between the IOB-BCU (poor connection)
                            • Nov 2009
                            • 27
                            Dear All, this case is closed. Power Supply issue.
