C3500 Color Counter
  • tinfox
    • 317
    [Misc] C3500 Color Counter
    How do you set the meter back from development counter to the regular counter?
  • mikadonovan
    • May 2008
    • 2931
    Re: C3500 Color Counter
    I believe that it can only be changed once, and then your stuck with it. SP 5045-001, set to "1"
    NEVER ASSUME ANYTHING
    • jonezy999
      just one copy??
      • Feb 2010
      • 952
      From what I can understand this is correct. Any idea why you can only change it once though?
      I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
      • Iowatech
        Not a service manager
        • 3930
        The way I understand it, the total copy counter is kind of considered by the legal community in the same fashion as an odometer in a car, and big trouble can occur if you change it for inappropriate reasons.
        So there's one chance to change it while setting up a machine, then it's done.
        At least that was what I was told.
        • ptrflrs
          Glorified Parts Swapper
          • Dec 2010
          • 192
          not sure about this model but a ricoh rep can change this through a special sp on certain models, I have seen this done on a 3260C back and forth but don't remember the special sp code
          jesus loves you! (everyone else thinks you're an assh*le)
          street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
          Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
          • Debs1964
            • Oct 2010
            • 1693
            I accidentally changed an MPC5502 to developments while taking off A3 double click and I changed it back with no problem
            There are 10 types of people in this world, those who understand binary maths and those who don't
            • Zeldaman
              • Mar 2011
              • 946
              • tinfox
                • 317
                I was able to change it back.
                • SargeNZ
                  • May 2012
                  • 263
                  I did this too. I didn't reset the machine before changing it back though. It may only 'stick' on reset.
                  • teebee1234
                    • Jul 2008
                    • 1670
                    As a side note, you can install mechanical meters as an option. They mount behind the cover at the rear side of the fuser by the fuser ps.
                    • mikadonovan
                      • May 2008
                      • 2931
                      Glad it worked for you. If I helped you out on this one, I sure could use some more green rep blocks
                        • 37532
                        As a side note: If you go to User Tools, System Settings, Administrator Tools, Display/Print Counters every machine I have worked on always prints pages not developments. It also give you scanning totals for FAX, email, and folders. This can be nice to know if you have a customer using the ADF for scanning more than for copying.
