Savin 9250SSP - Scanning issue
  • slamanna212
    • Jan 2013
    • 14
    Scanning to a network share
    A color image takes 10 minutes
    A Black and white image is instant
  • teebee1234
    • Jul 2008
    • 1670
    Re: Savin 9250SSP - Scanning issue
    Does it take 10 min for the scan to complete processing and then sent (memory goes back to 100%) or 10 min for the file to show up in the client. Is this a pdf or jpeg format? Try switching the two file types and see if there is a difference. Make sure firmware is up to date and then check your compression settings.
    • slamanna212
      • Jan 2013
      • 14
      They are using PDF
      I am not there yet, it was elevated to me from another tech. I will update post with more info/solution if i find one when i get there this morning.
      • rthonpm
        • Aug 2007
        • 2859
        Check the resolution that scans are set at: for general documents, 300 dpi is usually sufficient even if they're colour. Compression, like teebee said, is also a good setting to check.
        • slamanna212
          • Jan 2013
          • 14
          Ok im here now so i can give more info.
          There are 3 machines all using the same delivery server.
          PDF, 200 DPI
          1 machine works great, the other two take 10 minutes or more to send 2 or more sheets as a pdf when 1 or more of then have any color in them. It will say processing.
          Working:
          Savin 9040
          Not Working:
          Savin 9250SP
          Savin MP 7502
          • slamanna212
            • Jan 2013
            • 14
            Issue is resolved!
            Auto density needed to be turned on.
