RICOH AF1075 developer problem
  • msmy
    • May 2010
    • 123
    [Misc] RICOH AF1075 developer problem
    Hi,
    I have a problem with AF1075 which is the developer fly into drum unit (there are developer at drum cleaning blade)-but there are no developer in front of drum unit. I have no idea at all why and how it happen.
    I bought new developer unit (with new developer type 24) and also new drum. But, the problem is still there!
    please help...
    thank
  • fbkhan3
    • May 2012
    • 421
    Re: RICOH AF1075 developer problem
    Most probably it's bias issue with DV tank,
    Check bias terminal or board at the rear end,and make sure no pinched wires against fly wheel.
    Good luck!
    • JustManuals
      • Jan 2006
      • 9865
      Paul@justmanuals.com
      • msmy
        • May 2010
        • 123
        Hi,
        Still could not resolved the problem. there are no wire pinch at fly while. Changed with good working bias board. Anyone have other idea?
        • fbkhan3
          • May 2012
          • 421
          Then i'll go for a new DV Tank,
          Look this machine is an old beast,lot of wear and tear,If the Doctor Blade gape is out of position you can expect such things so you can swap DV tank from another working machine to diagnose.
          Good luck.
