base model ricoh 3000
  • advcopy
    • Jun 2012
    • 25
    [CQ] base model ricoh 3000
    i have an lanier ld 420c
    i have problem making color copies where the colors shade in the background i have done the line position adjustment in sp mode however did not solve it i have look though out the lists in spawn mode and can't see what might fix it any advice
    black and white come out picture perfect
    alrdy worked on the drum units
  • sandmanmac
    • 3981
    Re: base model ricoh 3000
    I'm unclear if you are talking about an overall background shading? or is it more of a double- image? Does it happen when printing or just copying? Can you upload a sample for us?
    • teebee1234
      • 1670
      It sounds like your grayscale setting has reverted to factory default.
      [Symptom]
      Background when ADS Mode is turned Off
      In Full Color the background is a process black, In Black and White mode the background is gray. With ADS on there is no evident backgrounding. When ADS is turned off and exposure is at the center setting, backgrounding is exhibited. Print Jobs and internal prints do not have background
      [Cause]
      The gray balance adjustment NV RAM Data has been corrupted and has reverted to the default value
      [Resolution]
      Reset the value of SP 4685 - 001 and 002, SP4686 - 001 and 002 and SP4687 - 001 and 002 to the value on the Factory Data Sheet.(Located under Jam Instruction Sheet on the Front Cover)
      If the Factory Data Sheet is not available try starting with these settings and fine tuning as needed.
      • SP4685-001 to -26 SP4685-002 to -26
      • SP4686-001 to -6 SP4686-002 to -6
      • SP4687-001 to -16 SP4687-002 to -16
      • advcopy
        • Jun 2012
        • 25
        [Symptom]
        [Cause]
        [Resolution]
        [LIST][*]SP4685-001 to -26 SP4685-002 to -26
        [*]SP4686-001 to -6 SP4686-002 to -6
        [*]SP4687-001 to -16 SP4687-002 to -16
        thank you very much this was indeed the cause of my troubles
        • Jomama46
          • 2900
          Glad you got it sorted out. BTW, what is "spawn mode" and where did you pickup that term.?
          sigpic
          A+; Network +; PDI+
          • advcopy
            • Jun 2012
            • 25
            my bad meant to say sp mode my phone auto predicted it -_-
            • Jomama46
              • 2900
              sigpic
              A+; Network +; PDI+
