MPC6502 / 8002 - Insider info?
  • Lagonda
    • Aug 2008
    • 1649
    Re: MPC6502 / 8002 - Insider info?
    Just had our first look at one and not overly impressed. Over complicated fuser and the 7502 is still only rated at 35% colour ratio. They are also staying with the toner in the dev idea but have boosted the amount of dev in each bag to 30%
    It aint going to be the replacement for all those toner dumping 7501's we have out there that are being flogged at 80% plus colour ratio. Oh well only six more years until retirement.............
    • msaeger
      • Sep 2008
      • 333
      The pro version is rated for 70% color.
      • slot
        • 341
        check out this link
        • teebee1234
          • 1670
          #19
          Not sure if it's a good thing or bad having the customer replaceable units. I can see benefits in it with the end user properly trained.
          • ricoh
            • Oct 2010
            • 14
            #20
            I can't imagine anyone outside of technicians in the real world replacing, for instance, the fuser unit. Even the PCU's will not be swapped by the customer with the exception of the over-zealous print for pay operator, which I am sure will lead to a call being placed.
            • semi
              • Sep 2008
              • 192
              #21
              Downloaded the SM couple of weeks ago
              • Coptech
                worker drone
                • 460
                #22
                Any word on what the replacement production B/W will be?
                • Bantams
                  • Jun 2012
                  • 603
                  #23
                  as this already been Replaced with a MPC6003?
                  • Coptech
                    worker drone
                    • 460
                    #24
                    The replacement for the 907,1107,1137?
                    • Imprestik
                      • Aug 2012
                      • 296
                      #25
                      This device will be replacing the MPC5502
                      • ricoh
                        • Oct 2010
                        • 14
                        #26
                        The replacement for these will be the same speeds. Although, rumour has it Japan tested the new "baron" series successfully to 250ppm. We won't be seeing that speed though unfortunately (?).
                        • Timmytronic
                          • Oct 2010
                          • 249
                          #27
                          Hi.
                          I was was thinking about up grading my MPC 7501's which I rent out for 6502 models. Has anyone any news if these are better machine, quality same or better I assume and the main thing, clean and hassle free....eg not dumping a ton of toner and need a vac out every 20k. Or would the pro 5100 be a better bet. For what I have seen online they are the same inside.
                          Any my advice would be great as my 7501's are close to the edge....of a cliff!!
                          Thanks guys.
                          Tim.
                          • Tonerbomb
                            AutoMajical Resolutionist
                            • Feb 2005
                            • 2589
                            #28
                            Originally posted by Timmytronic
                            Hi.
                            Thanks guys.
                            Tim.
                            How many threads do you want to the same post to be in??????????????????????
                            Mystic Crystal Revelations
