ricoh mp3025 scan to ymail ?
  • stupidkiller
    • Oct 2011
    • 57
    I've successful done with scan to yahoo mail with smtp.mail.yahoo.com and port 587 ( XXXX@yahoo.com ) but I fail to setting up scan to email with ( XXXX@ymail.com ) and I know yahoo mail & ymail is the same.anyone can help ? thanks
  • sandmanmac
    • 3979
    No they're not the same. Ymail uses encryption
    • stupidkiller
      • Oct 2011
      • 57
      Re: ricoh mp3025 scan to ymail ?
      so what should I do ? any setting ? thanks for ur help
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Use Google search (i.e. site:copytechnet.com ricoh email ssl) or the forum search, this has been discussed many times.
        See: http://www.copytechnet.com/forums/ri...-problems.html
        • sandmanmac
          • 3979
          Gee, I guess you might create a yahoo mail account and set it up that way.
            • 37379
            MP3025 is too old to support SMTP over SSL. If the customer insists on using ymail instead of yahoo mail, check with yahoo support to see if they provide a non-ssl smtp server (gmail does). If they do not, the try using an smtp relay such as Stunnel.
