SC 553 on Ricoh Aficio 2060
  • powshar
    • Jun 2011
    • 52
    We have a Ricoh Aficio in the field that keeps coming up with the SC 553. We have replace the thermistors on the fuser and have also replaced the hard drive. Any ideas?
    Your help would be much appreciated.
    Sharon
  • HP:guy
    • Feb 2013
    • 279
    Re: SC 553 on Ricoh Aficio 2060
    On the connector that mates the fuser with the machine loosen the screws and slide an E clip behind the bracket to insure better contact.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • powshar
        • Jun 2011
        • 52
        I have the manual, hence the changing of the thermistors, thanks.
        • Exok
          • Jun 2011
          • 750
          The end thermistor was at 240C for more than 1 second.
          Possible cause:
          PSU defective
          IOB control board defective
          BICU control board defective
          Goose guide also mentions if you have the error code followed by a please wait, a short in the fusing lamp harness damaged NVRam.
          • fshead
            • 2376
            Possible cause:
            PSU defective
            if you have a spare fuser i would swap out..
            sometimes changing the teflon roller if you did the thermisters already...
            i have also had power outage blow fuser codes,once all 6 machines on one floor over nite as electricians were doing work.
            • powshar
              • Jun 2011
              • 52
              Thanks, guys. In this instance, it turned out that the problem was with wires from one of the heat lamps in the hot roller having a bad contact. Problem solved!
