Yahoo scan to email
  • iscott
    • Mar 2010
    • 344
    Yahoo scan to email
    SMTP 98.136.185.95
    Port 587
    Not working for scan to email anybody else?
  • iscott
    • Mar 2010
    • 344
    Re: Yahoo scan to email
    Yes you can log in and send and retrieve from browser
    • sandmanmac
      • 3979
      Originally posted by iscott
      SMTP 98.136.185.95
      Port 587
      Same here. I had a couple of calls yesterday about the same issue.
      It seems that the IP address of the SMTP has been changed.
      I'm using xxx@yahoo.ca. I pinged the SMTP server,and used the 'new' one, and it worked fine again after that.
      No idea why it would have been changed. I'm expecting more calls today
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Why are you using the IP address and not the hostname? If you don't have a reliable DNS you can use Google's open DNS 8.8.8.8 or 8.8.4.4.
        • sandmanmac
          • 3979
          Interestingly, I could never get it to work with the SMTP Hostname with YAHOO, but I tried that again just for fun, and NOW that works too! - Just to add to my confusion
          • iscott
            • Mar 2010
            • 344
            Thanks got the new SMTP...
            • iscott
              • Mar 2010
              • 344
              Works in 2 out of 4 locations
              smtp.mail.yahoo.com
              I feel like yahoo is monkeying with their settings
              anyone know if GMX requires SSL?
              • poz31
                • Aug 2006
                • 86
                so instead of the IP use the SMTP.mail.yahoo.com (hostname)
                on the Ricoh interface???
                same port number?
                • sandmanmac
                  • 3979
                  same port number?
                  Works for me, so 'Yes' and 'Yes'
                  • iscott
                    • Mar 2010
                    • 344
                    Did that on this end worked on 2 of 4
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      smtp.mail.yahoo.com
                      Fortunately, GMX does NOT require SSL.
                      Plain ol' port 25.
                      Unless they've changed it recently, of course...
                      • sandmanmac
                        • 3979
                        Plain ol' port 25.
                        I've heard GMX is blocked by several domains due to excessive spam. Seems like there's some truth to that, because I just set up an account, and emails sent from GMX don't arrive in any my other email accounts
                        • Oze
                          Ricoh Fanboy
                          • 1663
                          Due to the sheer amount of spam to do with yahoo accounts we recommend to customers to use a gmail account....save a crapload of heartache and callouts.
                          • poz31
                            • Aug 2006
                            • 86
                            what values do you use to set up scan to email using gmail on ricohs???
                            I use this while using Yahoo...
                            Administrators email Address: (whatever you want)
                            Reception
                            Reception Protocol : POP3
                            E-mail Reception Interval : OFF
                            Max. Reception E-mail Size : 2 MB
                            E-mail Storage in Server : Off
                            SMTP
                            SMTP Server Name : 98.136.185.95
                            SMTP Port No. : 587
                            SMTP Authentication : ON
                            SMTP Auth. E-mail Address:
                            yourmail@yahoo.com
                            SMTP auth username: (your yahoo user info)
                            SMTP Auth. Password: change (enter your email password)
                            SMTP Auth. Encryption : Auto Select
                            thanxx in advance
                            • iscott
                              • Mar 2010
                              • 344
                              Those are the settings i have been using and they have been working up until Monday.
                              Don't use Gmail due to the fact that it requires SSL (To the best of my knowledge)
