PRO 906EX FAINT COPIES
  • katash
    • May 2010
    • 221
    [CQ] PRO 906EX FAINT COPIES
    Hi Guys!!
    problem with the pro 906 has constant faint copies and has done only 700k but i have replaced the PM parts and serviced the toner bank system and calibration done to no avail.
    apparently I'm not getting any service codes what astonishes is that the toner hopper unit has toner and when added by SP2207 works for sometime.
    any ideas will be greatly appreciated.
  • Polarbear
    • Feb 2012
    • 1070
    Re: PRO 906EX FAINT COPIES
    Have you checked your vsp/vsg values to see what the machine is doing?
    Press the GREEN button!!
    • katash
      • May 2010
      • 221
      polar,
      it varies when faint but when you set the CQ to be OK and perform TD sensor and ID its a go
      • watson
        • Sep 2009
        • 64
        Have you tried replacing the TD sensor?
        • gasior78
          • 29
          Had the same probem with a pair of 1357EX machines (Europe) doing the same thing, especially at a very long runs (same customer). Seems like Vref gradually goes up as a developer gets worn out, even when it did not reached its life (500k). After a certain Vref value the machine struggles to maintain the original 2,50V and pauses printing for much longer period to do a process control procedure. F/W error? I don't know. However it gets better after a manual forced 2-962 execution, not for long though. Anyway, in my case the only permanent solution was (is) changing the developer. This usually starts to happen at around 400k after the last PM.
          It used to be so much better in previous non-PRO models... Those were the days! /Kris
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • katash
              • May 2010
              • 221
              not yet but the developer is new,will try replacing though when you set the TD sensor the parameters seems to be OK i think I'll go a step further and replace the id sensor
              thanks guys for your valuable contribution.
