admin authentication Ricoh MP C500,MP 5000, MP 3350
  • force23
    Hi, i having problem on admin authentication,,, many of our machine on the market that automatically set the authentication on the system setting,, which is we cannot change any setting,, when time we deliver the machine we never set the authentication ON,, after 3 yrs of continious operation,, and its suddenly appear the LOG IN on user tools windows,, now i encountered some can log in and some cannot log in using "admin" or "supervisor".. we have 350 units on the market.. and its all MFP connected in one business network,, can you please tell me how can it happen.. i try memory clear NCS no luck and still cannot use admin..
  • HP:guy
    • Feb 2013
    • 279
    Re: admin authentication Ricoh MP C500,MP 5000, MP 3350
    You are up the creek with no paddle.
    Your only option is replace the nvram.
    • mikadonovan
      • May 2008
      • 2931
      You might look up the dickhead IT guy that changed it to begin with. If you tried supervisor>no password and that didn't work, I don't know what else you can do.
      NEVER ASSUME ANYTHING
      • sandmanmac
        • 3981
        Agreed! That shit just doesn't "happen"
        • jam-o-matic
          • Oct 2012
          • 72
          i feel your pain - our company bought back several machines off lease (mp6000 & mpc4500's) from a large bank, only to find them locked down tight and all passwords changed. I spoke to someone at Ricoh who walked me thru the old school TelNet, worked like a charm! I will dig up the instructions when i get in back to the office next week.
          • force23
            ok i'll be in touch.. hope your instruction will be helpfull.. thanks by the way..
            • jam-o-matic
              • Oct 2012
              • 72
              here are the instructions for clearing the settings (worked on Lanier LD360 & LD435c);
              print config page, or pull IP address thru settings
              connect via crossover cable to laptop computer
              open 'command prompt' (run - cmd) on computer
              type "telnet (ip address)" [note the space between telnet & ip]
              type "access flush" then hit enter.
              log out and save settings
              Good luck! Let us know if this works on these newer models??
              • skynetto
                • Sep 2012
                • 257
                access flush only removes the ip range allowed for wim access. It has nothing to do with admin and supervisor.
                • MitchD
                  • Oct 2012
                  • 164
                  Not true. I know a way to cure this problem.
                  "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
                  • mikadonovan
                    • May 2008
                    • 2931
                    OK
                    • vargue
                      • Oct 2011
                      • 404
                      there is some hazardous way to clear log in authentication.but counter will reset.00000000
                      • sandmanmac
                        • 3981
                        There are certain things many of us know, that should NEVER be discussed in an open forum.
                        Let's just leave it at that
                        • MitchD
                          • Oct 2012
                          • 164
                          I agree, just letting people know there are other ways of doing things
                          • force23
                            To All,
                            Guys, thanks for the instructions and options that all youve shared, i still have 1 more question.. Ist posdible not because of the firmware? And by the way i will try all the instruction youve shared..
                            Regards
                            • force23
                              Ok and how can i supposed to do that? It doesnt matter the if the counter back to zero... We count it from the start..
