MP W2400 Add Toner Sign On
  • DeathTeaM
    • Feb 2013
    • 16
    Add toner sign lights up but after replacing new toner is still the same.
    After checking the gears, toner spring clutch, and also replacing the developer, problem still occurs..
    What seems to be the problem.?
  • Polo-022
    • Sep 2007
    • 486
    Re: MP W2400 Add Toner Sign On
    Drum drive pulley spinning free, on drum shaft, believe it or not!!!
    Check setscrews, both...
    • DeathTeaM
      • Feb 2013
      • 16
      I believe I have already checked the setscrews and both are tight. Is it related to the ID sensor, powerpacks?
      • rsyarcia
        Hair Straightener Tech
        • 711
        when you replaced the developer are you able to print or copy atleast 10 pages or immediately the machine ask for toner? if that's the case you have to check the belts attached on the main motor(drives the dev't unit). make sure that the set screw and belt are tight. verify if the toner cartridge is for that model.
        Nobody is perfect..
        • DeathTeaM
          • Feb 2013
          • 16
          After replacing the developer, the add toner sign still came on. Just a few hours ago, i have replaced the ID sensor and everything went back to normal.
          Thanks to everyone who have gave suggestions. Appreciate it.
          • rsyarcia
            • 711
            ok great! that's new for me...
            Nobody is perfect..
