aficio 1035 network port 9100 close
  • Guest
    [Dead] aficio 1035 network port 9100 close
    firimware 5.25
    b0045102q
    Network connection is established
    Error when changing the rewriting was failed 900 ipp timeout setting
    Some options like disable netware
    Select a port in the sp mode 9100 does not affect the port is closed
    Only ports 21 and 23 and 80, 113, 990 and 995 are open
    Thank you
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: aficio 1035 network port 9100 close
    firimware 5.25
    b0045102q
    Thank you
    your post is not exactly clear. Are you trying to use port 9100 to print ? Some of the older ricoh's didn't use 9100 they used 10001
    Mystic Crystal Revelations
    • Guest
      Port 9100 is closed
      He can not open it
      • Guest
        Port 9100 is closed
        He can not open it
        port 10001 closed
