MP4000 & SC878
  • AleLeader
    • Oct 2012
    • 29
    MP4000 & SC878
    i have problem with MP4000 because i have SC878 error.
    I have change controller HDD , i used controller MP3350.
    Idea ?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MP4000 & SC878
    Replace the controller with the correct type, not from another model.
    • rsyarcia
      Hair Straightener Tech
      • 711
      Re: MP4000 & SC878
      did you used only the HDD of MP3350 or the controller board? i don't know if you can insert a controller board from MP 3350 TO MP 4000.just asking..
      Nobody is perfect..
      • JustManuals
        • Jan 2006
        • 9838
        Re: MP4000 & SC878
        Paul@justmanuals.com
        • sandmanmac
          • 3979
          Re: MP4000 & SC878
          Idea ?
          My idea is that if you used the MP3350 control board, you probably have 2 bad control boards now. Seriously!
          • AleLeader
            • Oct 2012
            • 29
            Re: MP4000 & SC878
            The part number is the same.
            • sandmanmac
              • 3979
              Re: MP4000 & SC878
              Really?? Then please, do share this 'universal' controller board P/N with the community.
              • Ricoh-ono
                • 338
                Re: MP4000 & SC878
                I think some of the misunderstanding might be that your post is in "broken English". Let me give it a try.
                You have replaced the HDD and the HDD-PCB PN#D3625170 (which is the same number on the MP4000 and MP3350). The error still remains after the swap?
                The SC-878 is an authentication error. Try reloading firmware if possible. If not, then you need to replace the controller PCB (this will be the larger board the HDD and HDD-PCB is attached to). There are 4 boards listed in the parts manual so make sure you choose the correct one based on your scanner type (color/monochrome) and speed (40ppm/50ppm).
                Do what you can, with what you have, where you are. ~Theodore Roosevelt
                • AleLeader
                  • Oct 2012
                  • 29
                  Re: MP4000 & SC878
                  i have replace p/n D3625180B and MP4000/MP3350 have this controller board
                  • rsyarcia
                    • 711
                    Re: MP4000 & SC878
                    my friend this is the p/n of MP4000 cotroller board : D0125734 and for MP3350 control board0195316. But the HD P/N of both machines are the same -P/N M3085130. Better buy a new HD don't use the old HD from other machine.
                    Nobody is perfect..
                    • AleLeader
                      • Oct 2012
                      • 29
                      Re: MP4000 & SC878
                      i have found here :
                      Ricoh_copier_parts
                      if search D3625180B
                      Now i have change HDD when FORMAT WITH CODE SPxxxxx is FAILURE.
                      • totoro
                        • 568
                        Re: MP4000 & SC878
                        D3625180B is actually the Hdd Controller Pwb for the Ricoh spc420dn. I'm not sure if it's compatible with the mp 4000\3350s, but maybe... This is a small board just for the HDD. Everyone is telling you to change the main controller board for the machine. I would listen to rsyarcia if I were you and order the parts he's listed for you. Good Luck
                        Totoro
