Error Code 22 Ricoh Duplicador Jp1250
  • irasema
    I'm trying to find what E22 code minds, I have to deliver an order tomorrow and my duplicador do not works!!!! Please help me!!!
  • neergish
    • 177
    I hope this helps, Ive never seen a duplicator in the flesh they seem.... Scary.
    "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
    • iMind
      Vacuum Cleaning Expert
      • Mar 2008
      • 1116
      I think you better call a Tech in tomorrow, thats not a job for a user to do, don´t try to invent on that machine, otherwise you going to spend a hack of money on your invention. Stay calm, theres nothing you can do.
      • irasema
        Thank You for the file, I fixed it!!!!!! I'm sooooo happy!
        Thank You, Thank You!!! The file you sent helped me a lot. I fixed my duplicator , it was the second timing sensor. It was disconected, probably with a paper jam that it had this morning.
        I'm so happy!!!!! I work with brides, they are specially difficult and do not understand if an order is not delivered on time.
        Have a wonderful evening
        Irasema
        • Muhammad-Anati
          Re: Error Code 22 Ricoh Duplicador Jp1250 c the sensors inside the rear side of the d
          Look at the sensors in the rear side of the drum and the small mettal attached to the drum it might be dameged
          • Polarbear
            • Feb 2012
            • 1070
            Neergish
            Don't be scared! Duplicators are actually very easy beasts, as there is very little that can go wrong.
            there is no laser unit or charge/transfer bias to worry about.
            It is basically a big stamping press - the image is scanned and written to a waxy sheet by means of a thermal head (same as in the old fax machines). Ink is forced through the holes in the waxy sheet, and placed on the paper that passes below the drum.
            It is all about timing and the thing is one big timing device.
            It is as easy as that!
            Better still - the DX series uses a soy based ink that is much less messy than the old JP range, that was almonst like diesel oil to try and get off your hands!
            Press the GREEN button!!
