I'm trying to find what E22 code minds, I have to deliver an order tomorrow and my duplicador do not works!!!! Please help me!!!
I think you better call a Tech in tomorrow, thats not a job for a user to do, don´t try to invent on that machine, otherwise you going to spend a hack of money on your invention. Stay calm, theres nothing you can do.
sigpicWe can all Win, but at the end we all loose.Save the greyhound
Thank You for the file, I fixed it!!!!!! I'm sooooo happy!
Thank You, Thank You!!! The file you sent helped me a lot. I fixed my duplicator , it was the second timing sensor. It was disconected, probably with a paper jam that it had this morning.
I'm so happy!!!!! I work with brides, they are specially difficult and do not understand if an order is not delivered on time.
I hope this helps, Ive never seen a duplicator in the flesh they seem.... Scary.
Neergish
Don't be scared! Duplicators are actually very easy beasts, as there is very little that can go wrong.
there is no laser unit or charge/transfer bias to worry about.
It is basically a big stamping press - the image is scanned and written to a waxy sheet by means of a thermal head (same as in the old fax machines). Ink is forced through the holes in the waxy sheet, and placed on the paper that passes below the drum.
It is all about timing and the thing is one big timing device.
It is as easy as that!
Better still - the DX series uses a soy based ink that is much less messy than the old JP range, that was almonst like diesel oil to try and get off your hands!
