scan to folder setup on mp c2800
  • fshead
    • 2360
    im not a big network guy as in the past my accounts had their own IT guys do the setups..
    having an issue wth a c2800 that i am told by offpremise IT support the server address and name/password..
    when i enter theinfo ie \\10.10.73.2\scans i get a window for loggin name and password..
    DOES this confirm the address is correct? if so is this anything that wld stop me from logging in?
    the folder is set up to share etc etc..and is used on older bo64 b/w copiers...
    i gotta go there for a 3rd time today and need to get this done.
    thnx
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: scan to folder setup on mp c2800
    If you receive a login message, that confirms the folder is shared. You will need to enter a valid network username and password which has read and write access to that folder. If the customer has a domain you may need to domain name qualify the username, i.e. domain\username or username@domain.
    • Jomama46
      • 2900
      Scan to SMB requires a user name and passord to authenticate the copier to the computer. Contact the person who set it up and ask them for the creds. Other wise, set up a new user on the computer and also use the same new creds on the copier in the file Transfer field.
      sigpic
      A+; Network +; PDI+
      • fshead
        • 2360
        thnx..
        i am dealing wth pc on lock down..the offpremises it support wont let me do anything..cant even drop a file from my flash drive on any pcs..
        they keep giving me a different name and password but needed to know that they are the problem..
        got the lates firmware to load and was wondering wth scanning conflicts which firmware do you do..does it pay to just do all?
        thnx
        • HP:guy
          • Feb 2013
          • 279
          If IT won't give you proper access set a time you can be on customer site and work with them to get it set up.
          • fshead
            • 2360
            i did set up a time but got caught in construction traffic going into city n ran 45mins late n they wouldnt
            wait..
            which i understand..i emailed the IT guy n told him to ask the office manager "who i know for 20yrs" if he could have the
            loggon info emailed to me..
            some of IT guys go crazy wth the names n passwords.lower case,upper case,numbers etc..
