Replace c/unit fuser mp5002
  • katash
    • May 2010
    • 221
    [Error Code] Replace c/unit fuser mp5002
    Good morning all,
    please assist!
    i have an issue of replace cleaning unit fuser unit but the copier is brand new!
    i have reset the counters but to no avail i went a step further and replaced the NV ram's but the error will not go!
    has any one come across this problem?
    thanks in advance.
  • Bantams
    • Jun 2012
    • 603
    Re: Replace c/unit fuser mp5002
    Somebodys broken the Little actuator off the end of the Cleaning web.
    • katash
      • May 2010
      • 221
      hi Bantams,
      the actuator is intact i think you mean the one when the web run out it stops with an error?
      • ZenElevations
        Was this issue ever resolved?
        • Counsel
          • Aug 2011
          • 529
          Either the web was out, or SP 1902-001 needed to be set to 0 if it was just replaced.
            • 37553
            This particular model is a bitch on the web. There are 3 SP's that have to be cleared when the web is replaced. The web consumption counter, SP 1902-001, needs to be set to 0. Web PM counter has to be reset with SP 7804-005. The Web parts counter has to be reset using SP 7806-008. Once they have all been reset you then have to power cycle the MFP.
            First time I had to do one of these I had to call Tech Support and find out what to do.
