Ricoh 1022
  • tcypy1961
    • 773
    Ricoh 1022
    What causes a black streak on backside of copy @ lead edge; from side to side. If multiple copies are made only shows on the first copy; yet on every single copy. Transfer roller or PCU unit???
    Thanks!!!
  • Drummer
    • Feb 2013
    • 46
    Re: Ricoh 1022
    Replace the pcu unit and all will be good again.
    • Jomama46
      • 2900
      Re: Ricoh 1022
      Both, PCU is overtoned and the transfer roller is dirty from the excess
      sigpic
      A+; Network +; PDI+
      • Iowatech
        Not a service manager
        • 3933
        Re: Ricoh 1022
        Maybe also turn on transfer roller cleaning? That's in SP2 service mode, near the end.
        • katash
          • May 2010
          • 221
          Re: Ricoh 1022
          Thanks!!!
          if your PCU is new check the quality of the toner if you have another type change it.
          • zsoltee0001
            • Jul 2009
            • 39
            Cause: the toner concentration of developer is too high.
            Solution:
            Change pcu , or developer, or use genuine ricoh toner ;-)
