MPC 3500 shows add toner all colors!
  • acsolutions
    • Jun 2010
    • 519
    [Error Code] MPC 3500 shows add toner all colors!
    Hello, all colors showing add toner, and when the customer runs more that ten copies it will give message to replace toner tubes. I tried replacing the toner tubes and the message never changes, and the indicates all show no bars left (empty condition). This tells me that possibly the RFID sensor is possibly not functioning. I'm not sure if I should clear out the engine memory or replace the RFID board. I guess there are also components in the mix like nvram main board etc. that can also cause this issue. I'm not sure what to expect when clearing engine memory, or what adjustment I will need to make after. Thanks
  • katash
    • May 2010
    • 221
    Re: MPC 3500 shows add toner all colors!
    HI, you can clear engine memory but you need to perform Forced Line Position Adj .it should sought the issue.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • ruben
        The New Guy
        • Oct 2012
        • 1204
        Have you replaced any of the pumps and pipes?
        • acsolutions
          • Jun 2010
          • 519
          it does not have an issue with copy quality, or toner getting to the dev. units. the main problem is it does not recognize a new or old bottle, it just thinks it's the same bottle. This to me is some communication issue. it just keeps saying replace toner on all four colors! Thanks
          • skynetto
            • Sep 2012
            • 257
            Take a look at this.
            Toner End Detection 2.doc
            Saved my a** a few times.
            • acsolutions
              • Jun 2010
              • 519
              [ATTACH]21197[/ATTACH]
              The problem is it's all 4 colors, I'll take a look though. Has this happened to you with all 4 colors? copy quality good. thanks
              • acsolutions
                • Jun 2010
                • 519
                *I went through the toner end detection which was very helpful!
                * First part sp3044-001 shows 0-2 I was set at 2 so then going to the next step sp5803-35,36,37,38 there was no change of state when removing the bottles, all 4 toners.
                *I then disabled the toner end detection and rebooted the machine, message went away. then ran about 25 sky shots so as to watch toner bottles rotate, they rotate then continues. I dont believe all toner end sensors are bad.
                *then checked the toner density sensor output. sp3201 Black2.94 Magenta 1.71 cyan 3.01 yellow 1.48
                then compared it to vtref sp3222 2.94 1.64 2.91 1.40
                all values seem to be in spec.
                * at this point the nvram could be an issue or I may need to clear the engine memory. like I said in the previous threads that quality is good and toner is getting to the dev.
                * any other suggestions would be helpful. Thanks guys
                • skynetto
                  • Sep 2012
                  • 257
                  Check for SC logs. Does it log something in the range on SC681-SC683?
                  Thats for RFID miss-communication.
                  Check also the OUTPUT CHECK with these SP:
                  5804 192 RFID ON/OFF:K RFID ON/OFF – K
                  5804 193 RFID ON/OFF:M RFID ON/OFF – M
                  5804 194 RFID ON/OFF:C RFID ON/OFF – C
                  5804 195 RFID ON/OFF:Y RFID ON/OFF – Y
                  5804 196 RFID COM ON:K Comunication RFID ON – K
                  5804 197 RFID COM ON:M Comunication RFID ON – M
                  5804 198 RFID COM ON:C Comunication RFID ON – C
                  5804 199 RFID COM ON:Y Comunication RFID ON – Y
                  • acsolutions
                    • Jun 2010
                    • 519
                    Cool, all kinds of stuff to check! I think these are the things I needed to check originally. Now are these out put checks done with the toner tubes in and out, or am I just checking to see if there turned on?
                    • skynetto
                      • Sep 2012
                      • 257
                      If there is a miss-communication when enabling the checks you should get an SC681-xxx with toner bottle on.
                      • acsolutions
                        • Jun 2010
                        • 519
                        Ok, so if the items are check and no comm. there will be an error. thanks
                        • Oze
                          Ricoh Fanboy
                          • Jul 2008
                          • 1663
                          I had this fault just this week...all colors reporting as near end despite the customer replacing toners.
                          Clearing NVRAM Engine solved it.
                          • acsolutions
                            • Jun 2010
                            • 519
                            when clearing the engine, are ther any adjustments after?
                            • skynetto
                              • Sep 2012
                              • 257
                              Forced alignment. Sp2 - 111. c once and a twice.
