savin 8045 admin code
  • youknowit
    • Jul 2025
    I am wanting to either reset the code or take it off, It is the administrator code to log in on the web interface and also when you are on the ui for the machine to log-in/out. This machine has no 7810, I have tried a memory clear on the ncs as well as the whole machine with no luck at all. We just received this machine back from a customer and they do not know what the password or log in is
    Thanks in advance for all your help!!!
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    Try login via network browser: username supervisor with no password. then you can change the admin password.
    • youknowit
      Thank you! I knew I had done that on another occasion but couldn't remember what the log in was for the life of me appreciate the help!!!
      • digicor
        • Jul 2008
        • 1156
        savin 8045 log in jam
        I have a savin 8045 locked up with admin access with no clue for the UN/PW
        I have tried a crossover cable to gain access but no luck either,is there a back door to this thing? do i have to set up a router to get to it,I was under the impression a crossover cable did the trick.
        • Jomama46
          • 2900
          supervisor is the backdoor!
          If that doesnt work you'll have to use memory clear, network settings.
          sigpic
          A+; Network +; PDI+
          • digicor
            • Jul 2008
            • 1156
            savin 8045
            Yes the supervisor got me in on the controll panel,
