Ricoh 3245c Turn sleep on power , LCd no display
  • spgnet
    • Jun 2013
    • 16
    [Dead] Ricoh 3245c Turn sleep on power , LCd no display
    This unit just turn sleep after power on, try remove all parts , PCU, Heater, Duplex , but no action
  • Eric1968
    • 2459
    Re: Ricoh 3245c Turn sleep on power , LCd no display
    There's an RTB about this problem.
    • techspec
      • Dec 2008
      • 128
      Check your laser unit and in particular the polygon motor.
      There is a small diode on the pcb that blows and it gives you a similar issue to the one your control panel is displaying. LCD dead and only green soft switch light displayed on control panel.
      There is a RTB for this.
        • 36249
        I had a similar problem a couple of weeks ago. Tech Support had me see if I could get in with the Web Image Monitor and check the machine status for any displayed error codes.
