ricoh mpc 4000
  • ed s
    • Aug 2025
    ricoh mpc 4000
    I have a ricoh mpc 4000 i bought from a wholesaler it is password protected and admin ansupervisor do not work. someone for whatever reason changed or deleted the factory Supervisor with no pass word login any other way to clear or by pass.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: ricoh mpc 4000
    You can either replace the NVRAM or contact the previous owner; see if they kept a record of the password.
    • ed s
      Re: ricoh mpc 4000
      I replaced the NVRAM and code 995-2 I put back original nvram and code went away are mpc 4000 and mpc 5000 the same nvram? I believe the one I used was for a 5000 do you have mpc 4000 part #. I know mpc3500 and 4500 are interchangeable. I assumed the same on the MPC 4000 5000. Thank you
      • stevie c
        Re: ricoh mpc 4000
        the code you have may be a serial number mis match.I think you may have to input the serial number in the sp mode section 5.
        • ed s
          Re: ricoh mpc 4000
          Thank you I'll try that tomorrow. Do you happen to know which one in mode 5 if not I'll scroll thew one at a time. I used nvram part numberD023-9590 is this correct?
          Thanks for the help
          • JustManuals
            • Jan 2006
            • 9838
            Re: ricoh mpc 4000
            Paul@justmanuals.com
            • Bantams
              • Jun 2012
              • 603
              Re: ricoh mpc 4000
              Thanks for the help
              Yes it is the same Nvram as the mpc2800/3300/4000/5000 also the error code is probably because you didn't dl the nvram data from the machine and put it onto the new nvram but you probably didn't do that because it will dl the login passwords ect.
              Make sure you print out all the non default sp mode data with the smc printout before replacing the nvram as you will need to input all the data that was set in the old nvram
              Oh and the Supervisor Login as a Password as default of supervisor or super cant remember which but its not Blank like the admin one is.
              • knightfall
                • Jul 2006
                • 633
                Re: ricoh mpc 4000
                it is supervisor and password is blank like the administrator by default.
                Get your facts first, and then you can distort them as much as you please.
                • Gary Bowen
                  Bowdog
                  • Mar 2008
                  • 250
                  Re: ricoh mpc 4000
                  I don't know if this is resolved yet, but not long ago Ricoh Tech Support gave us the following info to clear the password:
                  "Clear Modes" ,"1","4","3" "Clear/Stop", "Clear/Stop" (Hold the "Clear/Stop" keytop for about 5 seconds the second time and the machine should go into SP Mode). Enter SP5846-046 and Execute. This particular SP function IS NOt available in the normal or special SP Mode.
                  • sandmanmac
                    • 3981
                    Re: ricoh mpc 4000
                    There's a reason for that, Gary.
                    And some information simply does NOT belong in a public forum
