MPC4502 Single pass adf, black on CIS side?
  • turbojetboy
    • Aug 2009
    • 279
    I have been called in to assist a tech tomorrow that has a MPC4502 that has the single pass feeder. Single sided scans and copies ok but anything passing by the Contact image sensor (CCD array) for the second side is reproduced as pure black. I havent been in front of the copier yet, but he has replaced the CIS assy and the fault remains.
    Anyone seen this before?
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: MPC4502 Single pass adf, black on CIS side?
    I recently had a funky scanning issue on a MP4002, with black copies. You could copy say 5 originals, the second would turn all black at some point on the page and all the rest of the job would be all black. When rebooted it was fine for a while, but the symptom always returned. Turned out that the SIO( scanner I/O pcb) was bad.
    Mystic Crystal Revelations
    • TonerMunkeh
      Professional Moron
      • 3865
      When the CIS was replaced, was the stabiliser board also replaced? Have you tried updating the ADF firmware?
      Hit it.
      • turbojetboy
        • Aug 2009
        • 279
        Went out and looked at this machine, it was also camming over the fuser pressure roller with a ratcheting noise. After a bit of a think I checked the NVram values for the pressure motor timing, one was way off. Reset the value and the camming was fixed. It seems that somehow the NVram also spat the dummy on some of the adf values. After re-entering the values correctly it all came back to life. As it turns out the cust had some power difficultys and has a auto switching generator running a few times.....when all this started to happen.
        • ptrflrs
          Glorified Parts Swapper
          • Dec 2010
          • 192
          I was having those exact same issues and I found out that one of my esteemed colleagues (read as jerkface, douchebag, IT know-it-all coworker) reset the ram 5801 as instructed by ricoh tech support to solve a fax forwarding to email error. I'm not sure what setting fixed the fuser pressure motor from turning past the sensor but after a firmware update and re-entering all the factory settings it is back.
          jesus loves you! (everyone else thinks you're an assh*le)
          street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
          Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
          • PinevskiS
            • Jul 2009
            • 283
            Yes i have a same problem on mpc4502a.
            Cis (upper lamp) for the second side flash when i try to make duplex copy but copy is total black.
            • turbojetboy
              • Aug 2009
              • 279
              You almost certainly have corrupt NV ram values. get out the machines birth certificate (behind front cover) and check all values, you most likely will find one or more showing garbage numbers. That was the problem with the one I saw.
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                I've had the same fault after an Engine ram clear...re input of the birth certificate values fixed it...like turbo said.
                • SargeNZ
                  • May 2012
                  • 263
                  Is clearing board rams a thing now? It seems that in every second thread someone was recommended an 'engine clear', only to spend hours putting birth certificate data back in, and to have the problem remain. Maybe I don't get the same problems you guys do but I've never had to do such a thing.
                  • turbojetboy
                    • Aug 2009
                    • 279
                    It's my pet hate, unless you have a confirmed good backup of the Nv ram data.
                      • 37533
                      The usual recommendation is to never clear all memory unless you have a current backup of the NVram or at least have a current printout of all SP settings. The problem comes in when you have a corrupted NVram. Before going to the expense of replacing the NVram, try restoring settings from the birth certificate.
                      I have also seen inexperienced techs who don't look at the screen before pressing "Execute" and clear all memory, 5801, when what they were wanting to do was clear a fusing unit code, 5810.
                      • luiszr23
                        • Apr 2022
                        • 1
                        use this codes
                        in sp mode
                        4712 = 3666
                        4713 = 3741
                        4714 = 4082
                        its works for me
                          • 37533
                          Doing Sp 5801-002 Engine Memory clear might as well be SP 5801-001 as -002 is the damaging part of -001 both erase all engine settings, birth certificate tech made adjustments such as registration and edge erase margin.
                            • 37533
                            Sounds like a location that could use quality power protection.
                            • davel
                              • Oct 2011
                              • 1107
                              But the thread is almost 9 years old. Dead and buried.
