if the toner rubbs off, its your fuser unit(no pressure)if its your drum unit or dev unit,check when last u replaced the developer and drum. sometimes just by takeing the drum unit and the dev unit out and in will help aswell. it could be on your transfer roller aswell that is situated on the right side door. also check your vsp /vsg for 4.5volt then if its not right then u know the problem can be with your drum and developer. hopes it helps
It almost looks like you have moisture in your paper. Run a few blank copies through the machine and put the paper back in the paper drawer and make a full page copy and see if it works. If it does then get new paper.
