SC 520-00 (MP 2501sp)
  • sharpmind
    • Sep 2009
    • 478
    [Error Code] SC 520-00 (MP 2501sp)
    Guys, do you have any ideas on how to resolve this problem? The machine is still new. Try reseating all the connections but still error comes. I also checked the duplex unit. Thanks!
  • Polarbear
    • Feb 2012
    • 1070
    Press the GREEN button!!
    • sharpmind
      • Sep 2009
      • 478
      Re: SC 520-00 (MP 2501sp)
      Guys, if you don't mind, can you give me the part number of that registration motor...thanks!
      • skynetto
        • Sep 2012
        • 257
        This is the prove that Ricoh manuals are made by some dumbass.
        Parts catalog doesn't have a registration motor, it has a registration clutch.
        No way in the world I was able to locate it on the parts manual so if you are able to locate it please share
        The registration clutch is number 10 on the first pdf.
        • sharpmind
          • Sep 2009
          • 478
          Thanks for the info..God bless!
          • mlandry71
            • Sep 2014
            • 24
            So, has replacing the registration clutch solved this code?
            The reason I ask is that I have a client with a MP2501sp with this SC520.
            I have cheated the door and while manually turning the roller and activating the registration clutch in OUTPUT CHECK, the clutch does indeed grab and stop me from turning the registration roller.
            (I had to boot the machine with a door open and go into SP modes or else it throws the code immediately and nullifies OUTPUT CHECKS)
            Then, I can also reach around to the back and, while having the clutch still on, manually turn the main motor and feel that the registration roller is turning with no abnormal binding felt at the motor. But as soon as i try activating the main motor, the motor makes a slight jog then stops with the sc520 thrown.
            So. I am starting to assume that the code description should be Main Motor Error. Would anyone agree? Therefore, I will be trying a Main Motor replacement as a fix.
            Thoughts? Suggestions? Links to a solution I missed somewhere?
              • 37403
              The problem is not with the parts catalog. The problem is with the error code and description. If you look at the start if the SC 5xx service codes, you will notice one thing glaringly not there. No main motor lock, SC500. The registration roller clutch is driven by the main motor. Trouble shoot as a main motor lock.
              • Polarbear
                • Feb 2012
                • 1070
                Don't we know it!
                try making sense of an MP161 manual. Especially the firmware upgrade section.
                First there is mention of PCMCIA cards, the SD. Then the photo shows a PCMCIA slot??!
                Lol!
                  • 37403
                  Originally posted by Polarbear
                  Don't we know it!
                  Lol!
                  The service manual covers multiple similar models. Original Aficio MP 161, product code B262/B292, uses the PCMCIO cards. When the GW controller models, B284/288, they added the procedure for the SD card was added but the pictures of the screen displays were not.
                  • PaL14
                    Hello!
                    Error SC520-00
                    In my cause jammed Photoconductor Unit - in the Developer section jammed auger because of the excess toner in it
                    • Gift
                      • Mar 2011
                      • 2459
                      This unit is a total downgrade engine- and construction wise compared to the MP2000 (and that wasn't really my favourite, too^^) - luckily I was able to concinve the sales people to avoid selling these.
                      • fbkhan3
                        • May 2012
                        • 421
                        I still have one MP2501 with SC520 waiting to get new Main drive Motor ,i will post an update.
                        totally agree with (Gift)that MP 2000 engine is much solid and reliable comparing to this .
                        Regard's
