Ricoh 1015 toner feed prob
  • evest
    • Aug 2008
    • 58
    Have a cust with a 1015 and I did a complete PM, drum and DV included. Calibrated the Developer but the machine runs the toner out of the mix. It takes about a month to do so. So I go in and and toner and recalibrate. I check to see if Toner Bottles moves and it does. What do I do?
  • sandmanmac
    • 3985
    Re: Ricoh 1015 toner feed prob
    So how do you get the add toner light to go out? Add it manually to the dev unit? Or does forced toner take care of it for a while? This problem did not exist prior to the PM? Oem toner? Have you disassembled, cleaned and checked the 4 mylars within the hopper unit?.
    More info please
    • evest
      • Aug 2008
      • 58
      Panel does not ask for toner. The developer is not asking for toner. I calibrate it and works for a while. don't know if this problem existed before PM. OEM toner
      • Eric1968
        • 2458
        Did you use the right bag of developer. I once accidently poured Type 28 in a AF1018, and it worked for a month.
        • redneckstylin
          • Sep 2011
          • 173
          toner hopper?
