Have a cust with a 1015 and I did a complete PM, drum and DV included. Calibrated the Developer but the machine runs the toner out of the mix. It takes about a month to do so. So I go in and and toner and recalibrate. I check to see if Toner Bottles moves and it does. What do I do?
Ricoh 1015 toner feed prob
Re: Ricoh 1015 toner feed prob
So how do you get the add toner light to go out? Add it manually to the dev unit? Or does forced toner take care of it for a while? This problem did not exist prior to the PM? Oem toner? Have you disassembled, cleaned and checked the 4 mylars within the hopper unit?.
More info please -
