weekend puzzle this is a good one
  • redneckstylin
    • Sep 2011
    • 173
    i have a c3300.....im stumped maybe over looked something
    replaced
    -nvram
    -pcus
    -devs
    -bicu
    enjoy this is a good one
    sp 4417 is at default 0 aswell
    thanks in advance
  • redneckstylin
    • Sep 2011
    • 173
    Re: weekend puzzle this is a good one
    oh ya forgot to mention
    only print jobs perfectly straight cyan lines
    copy works great
    this is only internal prints and color test patterns
    • anothertech
      • 1771
      GW Controller?
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        Could be a faulty memory module, check the RAM on the controller and try swapping with another working machine.
        • teebee1234
          • Jul 2008
          • 1670
          Try a memory clear on the Printer function only- SP5-801-008, then try a calibration.
          • imaginemoko
            unTrusted Tech
            • Jan 2008
            • 289
            have you tried to reset the controller board? as already mention above try sp 5801-8 printer application clear... good luck
            fix the customer first then fix the machine... its simple and makes life more easy.
            • zames77
              Tweak it till it breaks!
              • 121
              Had a similar issue but was with white deletions through the black, looked like it was the laser, but ended up being the IPU. Worth a try.
              • zyqwiz
                • Jun 2009
                • 333
                HDD?
                replaced
                -nvram
                -pcus
                -devs
                -bicu
                thanks in advance
                • Bantams
                  • Jun 2012
                  • 603
                  Try setting SP4685-01 and 02 and SP4586-01 and 02 and 4587-01-02 to there default Values on the SP MODE FACTORY SETT sheet behind the front cover if its missing set them to 4585-01 and -02 to -73 / 4586-01 and-02 to -58 / 4587-01 and -02 to -66 I've had to do this in the past for similar Fault usually its Magenta Background.
                  • redneckstylin
                    • Sep 2011
                    • 173
                    have tried
                    - hdd
                    - reseating controller
                    - swapped gw
                    - different memory
                    - sp 5801 -001 and 008
                    - ipu
                    - sbu
                    - psu
                    • redneckstylin
                      • Sep 2011
                      • 173
                      also have put book and df reads back to factory specs
                      • ptrflrs
                        Glorified Parts Swapper
                        • Dec 2010
                        • 192
                        The laser writes at different resolutions and powers to discharge the drum charges for prints and copies. Have u tried swap testing the laser or at least reseating the connectors to the laser on both ends? Might be a pinched wire somewhere, also.
                        jesus loves you! (everyone else thinks you're an assh*le)
                        street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
                        Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
                        • redneckstylin
                          • Sep 2011
                          • 173
                          tried that aswell thanks though that's what I thought at first it was laser unit swapped with different lsu
                          • SargeNZ
                            • May 2012
                            • 263
                            You have tried printing via USB and from your own PC outside of the client network? What about internal prints? Printer SP 1103-2 for colour test page.
                            • redneckstylin
                              • Sep 2011
                              • 173
                              internal print sp1103 is that blue grid pattern
                              auto color calibrations are the blue grid pattern aswell
