MP 2352 Please wait message on screen
  • 3bok3bok68
    Senior MFP Technician
    • Nov 2008
    • 56
    "Please wait" message during installation MP2352, disconnect hdd still same. Replaced controller board, IPU, BCU and finally PSU same and not success. Thus anyone encounter this trouble? Please help. Thanksin advance...
  • JustManuals
    • Jan 2006
    • 9838
    Re: MP 2352 Please wait message on screen
    Paul@justmanuals.com
    • Herostrat
      • Oct 2012
      • 220
      Is fuser assembly warming up?
      At this point all I can think of is Aficio 700 when it bugs up and gives me this without SC or anything,or simply won't go in ready state and fusing assebly is cold.
      Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
      • 3bok3bok68
        • Nov 2008
        • 56
        Yes trusted fusing is warming up....
        • HP:guy
          • Feb 2013
          • 279
          have you looked up TB 013 I tired to upload it but it errors out.
          • 3bok3bok68
            • Nov 2008
            • 56
            Hi HP nope i did not see that TB 013, if you dont mind can you please send to me you said TB? thanks.
            • dawn
              • Mar 2011
              • 48
              Try replacing laser unit.
              • Athlontini
                • Jun 2012
                • 269
                Replace the NVRAM and the EEPROM chip on the BCU. When that chip is faulty/broken pins, it causes this exact symptom.
                • 3bok3bok68
                  • Nov 2008
                  • 56
                  Athlontini I take BCU from new machine and test it in the machine which have a problem but still same until all parts of the machine I canivalized transfer in the machine no success..
                  • Athlontini
                    • Jun 2012
                    • 269
                    If you call Ricoh they're likely to tell you to replace both the BCU and EEPROM, brand new, together as a set. If it was a brand new machine you cannibalized them from then I guess we'll rule them out.
                    Are you getting appropriate voltage from all connector pins on the power supply?
                    • 3bok3bok68
                      • Nov 2008
                      • 56
                      Yes! All voltage are okey. The cannibalized machine I already installed in the customer its work fine! I experience this problem many times only disconnect the HDD its work.
                      • rsyarcia
                        Hair Straightener Tech
                        • 711
                        you almost changed everything inside the new machine. maybe it's time to change the engineer("Please don't wait).just kidding. were you able to access the sp mode?
                        Nobody is perfect..
                          • 37324
                          If it has a FAX option installed, remove the FAX option. If that allows it to boot, replace both the GWFCU and the MBU.
                          • 3bok3bok68
                            • Nov 2008
                            • 56
                            There is no fax option installed in the machine slimslob...
                            • 3bok3bok68
                              • Nov 2008
                              • 56
                              No rsyarcia I can't access sp mode...thanks...
