MP3352 led stand by on
  • buttalasso
    • Jul 2025
    Hi everybody, I have the machine in the object that has a strange (for me) problem: I power on the machine, the led of the stand-by is on, from the power board I hear several clicks, but any motors don't moves, the display is off.
    The fuses are ok, I checked the 5V and I founded on the RED wire, I checked the 24 V but I didn't found on the white wire.
    I think that may be the power supply unit (AZ23 0257)or the PCB: SDb (M026 5194).
    Anyone had my unlikely problem?
    Thanks a lot
  • Jomama46
    • 2900
    Re: MP3352 led stand by on
    White wire is ground. May be the PSU but more likely a controller or BCU issue.
    sigpic
    A+; Network +; PDI+
    • buttalasso
      The Ricoh tech told me that the white wire was 24v, I'll check better the right wire. When I power on the machine, I hear several click on the power supply side; I think that this strange rumour could be referred to the power supply unit, do you think it could be the controller?
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • kannuki2
          • Feb 2012
          • 398
          I could be the capacitor on the pSu is burned but you cannot see it. Just try a new PSU and take it from there.
          • buttalasso
            I've changed the PSU, BICU and IPU. The problem is the same. I'm waiting for the Controller, but I'm not so optimist..
            Any ideas?
            • Bantams
              • Jun 2012
              • 603
              Could be the laser motor and or bicu shine a torch onto the touch screen to see if its showing any sc codes.
              • zsoltee0001
                • Jul 2009
                • 39
                Is there a short circuit in 24v circuit?
                It can down the power supply
                • zsoltee0001
                  • Jul 2009
                  • 39
                  plug in the all connector of dc motors .
                  You have to try , where is the problem.
                  • buttalasso
                    Any ideas?
                    The controller is just arrived and solved the problem.
                    Thanks everybody for the help, I appreciated it.
