need some help
  • luis8832
    • Dec 2008
    • 250
    [Misc] need some help
    I have an Ricoh aficio MP 161. Used to work on ricoh's years ago, want to program the fax side of it and set up for smb scanning. If anyone has some input, a manual that i can use on programming this unit it would be helpful. Thank you all in advance for all your help.
  • rthonpm
    • Aug 2007
    • 2854
    Re: need some help
    Manuals, Drivers, Software and Brochures Downloads | Ricoh-USA<
    User manuals can be found there. The MP 171 manual will also work as there's not much difference other than colour scanning and a few add-ons between the two models.
      • 37491
      Re: need some help
      Be aware, if you are going to use SMB scanning to Windows 8 or Server 2012, you will need to down load custom firmware from Ricoh.
