ALL Toners indicate EMPTY
  • AlanHubb
    • 6
    [Error Code] ALL Toners indicate EMPTY
    I have here a Ricoh MPC 3500 with very strange toner issues.
    The machine has a FULL set of new toners but still indicates in the colour level chart that ALL toners are out.
    plus, on the bottom left of the touch panel it has been saying "Cyan almost empty" for the last 3 months.
    But, after all this going on, the machine still works with no problems at all.
    i have changed the Cyan toner pump and tube, along with trying other toner cartridges. (still no luck).
    surely there has to be some sort of reset code in SC mode?
    thanks.
  • JustManuals
    • Jan 2006
    • 9838
    Re: ALL Toners indicate EMPTY
    Paul@justmanuals.com
    • Eric1968
      • 2458
      Are you using OEM toner or that aftermarket sh.t?
      • AlanHubb
        • 6
        Im using Original OEM toner. (the good stuff).
        • Eric1968
          • 2458
          Have you checked any SC-codes that are logged? Could be an RFID-problem.
          • katash
            • May 2010
            • 221
            thanks.
            you need to do engine firmware and system should sought you out
            • Toledo
              thanks.
              check the following
              SP 3901 001 NEW PCU DETECT (SHOULD BE '1')
              SP 3902 001~012 MANUAL NEW UNIT SET (SHOULD BE '0')
              • ruben
                The New Guy
                • Oct 2012
                • 1203
                Or, faulty RFID board.
                  • 37550
                  Since all four are bad it could be a loose connection to the RFID board or a bad board.
                  Process Control, MUSIC, and TC Adjustment are all forbidden during toner near end. Change SP 3519-001,002,003 all to 0 to permit these function when add toner is displayed. SP 3045 can be used to disable Toner End Detection.
                  • Bantams
                    • Jun 2012
                    • 603
                    Hopefully he's either fixed it or scrapped the mofo in the last 3 months since creating this thread
                    • collme
                      Ricoh tech
                      • 221
                      why scrap a perfectly good model of machine J lol
                      • Helios
                        It seems that these lot of machines are bad for not detecting new toner. 4502's seem to give me the worst grief when it comes to this problem.
