Ricoh mpc5000 electronic counter no grows up
  • unitechro
    supervisor
    • Feb 2012
    • 9
    hi guys,
    MPC5000 electronic counter no grows up even if i make copy?
  • Jomama46
    • 2900
    Re: Ricoh mpc5000 electronic counter no grows up
    Which counter are you looking at? UT or SP?
    sigpic
    A+; Network +; PDI+
    • Iowatech
      Not a service manager
      • 3930
      Originally posted by unitechro
      hi guys,
      Can you post a picture of how the copies look now?
      • unitechro
        supervisor
        • Feb 2012
        • 9
        hi,
        in menu user tools/counter/123 counter:
        we have electronic counter dev counter or page counter (5.045.0 or 1),if i do one copy this counter must be + 1 .
        but it doesn t work,if i go in user tools/printer features/ print config ;by PC to printer :same problem.
        no problem with quality or density .
        electronic counter in menu user tools/counter/123 counter seems blocked.
        client must send me 5.990 all ,i wait to see 7.803/7.804/8001 etc...
        firmware version? controller nvram defect?
        • Jomama46
          • 2900
          hi,
          Is SP5045 at "1"?
          I dont thinks its the NVRAM because 5990 is working. Controller maybe.
          sigpic
          A+; Network +; PDI+
          • unitechro
            supervisor
            • Feb 2012
            • 9
            Originally posted by Jomama46
            Is SP5045 at "1"?
            hi jomama,
            5.045 is to 0 (initial position) cause i ve page counter.
            client must send me 5.990 all ;tomorow .i ll see all 7.803.804 and 8 menu to verify all counter) .at frist i ll put 5045 0 to 1 (to have development counter and see if it moves) and try to insert (another time) firmware copy/system and engine ( we ve last firmware in machine).i think problem come from firmware up date or controller nvram fault.
            • Jomama46
              • 2900
              5945 to 0 means it will count development cycles not copies. However it should still be "growing"
              If you changed it back to 0 after being at 1, that may be the problem. I have never encountered it but the manual says you can only change it one time. You may have to replace the controller and NVRAM.
              sigpic
              A+; Network +; PDI+
              • unitechro
                supervisor
                • Feb 2012
                • 9
                hi,
                thk for your help jomana46
                the technical dealer send us 5.990.1 ( we re broker,and we compare it with our original sp5.990.all, we have it for each copier sold ) :
                we find 5.045 to 2 ???? and they say :they 're technical and dealer :
                i don't known why they put to 2 sp 5.045 : they said it was in order to have counter copy with % for color and black
                they re supposed to be "real technicals" and supposed to open technical manual to see that to put 2 doesn't existed .and see all they want in sp menu 8.
                results:
                All counter in 7.804 ok
                All counter in 8 ,user menu counter ,printer config counter fault.
                it s their own responsability ,we will probably sell them nvram and controller.
                i ll post final result
