when customer is printing on full colour it jams in the fuser wrapping around the fusing belt even when there is an inch of white leading edge.
i replaced the fuser unit from another machine and still had the same problem. and alsochanged the exit section with no effect.
i then went out and bought a different brand of paper 80gsm and still jammed. previous paper weight was also 80gsm
i lowered the fuser temperature and still jammed inside the fuser. black and white prints are fine.
changed the paper size to landscape and it worked fine on full colour.
customer still wants it fixing on portraite so i need to go back with a solution.
anyone ideas??
thanks
anyone ideas??
thanks
