mpc2551
  • katash
    • May 2010
    • 221
    [CQ] mpc2551
    please assist!
    faint copies on this model and have replaced parts and upgraded firmware,any ideas will be really appreciated
  • Gift
    • Mar 2011
    • 2459
    Re: mpc2551
    where do the image get fainted? on drum? transferbelt? - you can test if you interrupt the print and check the surfaces
    • Zeldaman
      • Mar 2011
      • 946
      Re: mpc2551
      Hi there!
      Only copies, or prints too? Which parts changed? Scanner-section clean? ACC? A little bit more information please.
      Greeetings...
      • katash
        • May 2010
        • 221
        Re: mpc2551
        Originally posted by Gift
        where do the image get fainted? on drum? transfer belt? - you can test if you interrupt the print and check the surfaces
        stopped the print job before the transfer area and when u look at the drum its a faint print,do i replace the LDunit as its clean.
        • katash
          • May 2010
          • 221
          Re: mpc2551
          Originally posted by Zeldaman
          Hi there!
          Greeetings...
          greetings,
          both printing and copying,pcu assy's replaced
          • Gift
            • Mar 2011
            • 2459
            Re: mpc2551
            just the drum or dev unit as well? in case the dev unit hasn't been replace you can try toner add via sp and see if the density improves. what about C/M/Y - do the colour looks weak as well?
            You might check all HV/bias/ground contacs
            • SargeNZ
              • May 2012
              • 263
              Re: mpc2551
              Going right back to basics, did you clean the LD glass with the little wand thingy? Is the drum/dev up to PM?
              • katash
                • May 2010
                • 221
                Re: mpc2551
                yes sargez,replaced drum units for color only and black plus dev unit but the problem is even on color its faint was even before the pm change
                • Iowatech
                  Not a service manager
                  • 3930
                  Re: mpc2551
                  You said you replaced parts, could you tell us which parts you replaced? Because that sure looks like you just have a worn out PCU, and the numbers on the image you shared make it look even more so.
                  • katash
                    • May 2010
                    • 221
                    Re: mpc2551
                    hi iowatech,
                    the parts replaced as stated earlier are drum units for color without dev units plus drum unit and dev unit for black
