MP6002 SC555 every morning
  • sg01
    • 16
    [Error Code] MP6002 SC555 every morning
    Anyone in the region facing MP6002 giving out SC555 every morning.
    customer will switch off machine after work in the evening.
    all internal heaters connected, thermistors and thermostats has been changed 2 sets.
    could this be an issue with the controller?
  • katash
    • May 2010
    • 221
    Re: MP6002 SC555 every morning
    NO,theirs a bulletin on how to deal with this the connector male on your fusing unit needs extra bushes to firmly connect to the connector at tha back of your copier
    • Polarbear
      • Feb 2012
      • 1070
      This RTB is also regarding SC555
      It talks about cold areas and settings on the SP modes regarding temp detection. Hope it helps!
      Press the GREEN button!!
        • 37529
        This bulletin has also been released TSB 007 Reissue for the MP 6002. Dated 6/25/2013. It also mentions that buildup on the thermistors can the problem.
        The only difference betweemn the two bullitens is that 007R says to be certain that firmware D1315127C_Engine_vLR0603_SD.zip is installed.
        Is there a reason that the customer turn the 6002 off every night?
        TSB007Reissue.pdf
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
          Paul@justmanuals.com
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            555 is nothing new to this whole series, you'll find many posts for this on any machine in the 55-90 ppm ricoh's. Anything from replaceing the fuser harness to disableing AOF, cleaning the pins for the springs on the machine connector for the fuser.... check your power also......
            Mystic Crystal Revelations
            • Imprestik
              • Aug 2012
              • 297
              I have been working on this issue for a while now, both SC555 and SC552, I am currently testing a newly developed cleaning web that I was told should eliminate this
              Part number is AE04 5069 if anyone wants to order it. Apparently it cleans the hot roller better which should eliminate both codes, only time will tell
              • tlf
                • 39
                I checked on the price of this roller part # AE04 5069 ricoh was 114.00 dollars for it a normal roler is 37.00 to 43.00 i was shocked at the price of it we have 2 coming to try
                • Imprestik
                  • Aug 2012
                  • 297
                  I can't help you with pricing my friend but I think all new cleaning web's being made now are going to be designed like the AE04 5069. They seem to contain a lot more oil than the older ones.
                  The only thing that gives me the shits is that we never used to have this issue when there were 3 lamps in the fuser, ever since they have gone to this 2 lamp system, the fuser has become the weakest part of the device.
