ricoh 220 feeder
  • pcb0960
    ricoh 220 feeder
    hi, I have a problem with the doc feeder skewing
    slightly I think I figured it out it has to do with the metal bar, or the plastic turn guide right before the metal plate (hope I am describing this correctly) also the machine then started feeding two sheets when only one is in the feeder, I think that was because the machine was under a flourescent light. now this machine is not copying off the glass, but it will start feeding from the feeder without paper
    in the feeder.....TIA Patricia
  • DQYDJ
    Re:ricoh 220 feeder
    SOUNDS LIKE THE PAPER PRESENT SWITCH IN THE FEEDER IS EITHER
    STUCK OR THE ACTUATOR FOR THE SWITCH IS MISSING SO IT
    THINKS THERE IS PAPER IN THE FEEDER ALL THE TIME.
    AS FAR AS THE SKEWING GOES YOU MAY HAVE WORN FEED ROLLERS
    AND OR WORN SEPERATION BELT OR ROLLER DEPENDING ON WHAT
    IT USES. IF THE ROLLERS ARE GOOD YOU NEED TO CHECK THAT THE HIEGHT
    OF THE FEEDER IS THE SAME ON THE FRONT AND REAR . UNEVEN HIEGHT
    IS THE MOST COMMOC CAUSE.
    • SGT_Snacks-64
      • Oct 2007
      • 157
      For a start you should make sure all the sensors on the DF are clean (use Alcohol) check the sensors under Mode 5 in SP Mode against the Service Manual. Make sure the Feed tyre, belt and sep roller are within life, if not these should be replaced to help troubleshooting.
      Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
      Asus P5E-VM HDMI
      4GB (2x 2GB) Corsair XMS Xpert II RAM
      ATi Radeon 4870 512MB GFX Card
      2x 74GB WD Raptor Sata HDD (RAID 0)
      500GB Seagate Barracuda Sata II HDD
      500GB Hitachi Sata II HDD
      600W500att OCZ PSU
      -TOTAL HDD SPACE 1148GB-
