Ricoh 1045/ Sc 672????
  • copiadoratecnicad
    • May 2025
    helps, like I unblock code SC672
    with this message in screen cannot make Adj.
  • Ricoh-ono
    • 339
    try unplugging the harddrive and reboot. If it still comes up with a 672 then your controller is probably f*cked.
    Do what you can, with what you have, where you are. ~Theodore Roosevelt
    • copiadoratecnicad
      you believe that rebot the hard disk press (*) + (#) + power on ????
      • iMind
        Vacuum Cleaning Expert
        • Mar 2008
        • 1116
        Mr. nickname said, unplug the hard disk, this means desconnect the drive. there is a new firmware for that SC. turning off and back on this service call is normally cancelled.
        • copiadoratecnicad
          Thank you for your suggestion, but the HD already disconnect and SC 672 persists, doesn't walk
          • Ricoh-ono
            • 339
            Well, it looks like you will have to replace the controller.hehehe
            • copiadoratecnicad
              Thank you friends, excuse that it bothers a lot.
              Today I face to this it schemes, later I count them that it happened.
              • Jomama46
                • 2900
                As IMIND says, there is new firmware to correct this, try that before replaceing the controller.
                sigpic
                A+; Network +; PDI+
                • paulg
                  • Jun 2007
                  • 278
                  As well as firmware you have checked the connections between the controller and the keyboard/op pannel? It has been known for the cable between scanner unit and controller to get dammaged or twist.
                  Sometimes better to check the simple fixs before swapping the whole board over.
