Hello!
We have a Ricoh Aficio MPC7500 that we purchased at auction. Recently we had a problem with blue streaks on all pages whenever we printed in color. Right before the service technician came out we received Error SC534. We powered down the machine as instructed but still we received this error. When the service technician arrived he indicated that there was also a second hidden error (Error SC670).
The technician stated the first error was a duplexer fan error - the fans run properly (he could start the fans from the diagnostics) but the system is seeing a "fan motor seized" fault and thinks there is a problem with the fans. The technician's diagnosis was that there was probably a blown capacitor and the VBCU should be replaced.
The technician asked if we had lost power (we had not, at least not as far as we where aware). My question is this: would it be of any benefit for us to try updating the firmware on the VBCU before we go into the expense of replacing it? Also, any other suggestion/recommendations would be greatly appreciated.
Thank you!
Thank you!
