MP 6001 cannot access web image monitor
  • jtymabel
    • Aug 2008
    • 164
    Cannot access Web Image Monitor....i can telnet to the machine, but no luck with web image monitor. I checked to make sure SP5828 was on for telnet and web. i tried clearing the nvram for web and ncs, but i could not (see attached picture). I will pull out the fax board to see if this is causing it (saw a similar post that was resolved with the removal of the fax board)
    thanks
  • sandmanmac
    • 3985
    Re: MP 6001 cannot access web image monitor
    Does everything else work? Printing and scanning?
    If not,
    What about SP5985-001 (on board NIC)
    0: OFF, 1: ON, 2: ON: Limited
    When the "Function limitation" is set, "On board NIC" is
    limited only for the @Remote or LDAP/NT authentication.
    ƒ Other network applications such as
    WebImageMonitor, @Remote, or LDAP/NT
    authentication are not available when this SP is
    set to "2". Even if you can change the initial
    settings of those network applications, settings
    may not actually work.
    * Even if it is at "1" already, you might try changing it to something else, rebooting, and then back to "1"
    • jtymabel
      • Aug 2008
      • 164
      If not,
      Thanks...i noticed it was set to "2" will set it to "1"
      Printing, scanning and LDAP seach works normal.
      will keep you posted.
      thanks again.
      • jam-o-matic
        • Oct 2012
        • 72
        Is it a previous working machine? If not; we got a bunch of these machines back from a bank, and of course they were locked down tight! On ours, you could access almost everything, except WIM nor print to it. Bank changed passwords & wouldn't play nice and share (or change back).
        If you go to Print List (user tools, system settings, interface settings) it will show you if the access control is limited to a certain IP range, I was able to cross over (with my laptop in their range) and WIM then delete the access limits.
        Good luck!!
        • jtymabel
          • Aug 2008
          • 164
          thanks again.
          Excuse me for not posting sooner..
          Set to "1" machine works great and WIM is up and running.
          thanks
